Server Move 21.05.2013
Excellent (y)
I'm just playing about with the Google Analytics code, as where XF insert it originally, it's causing a delay with the header being generated. Google recommends putting it before the </body> tags, so I've created a custom template and I'm also hosting the javascript locally and serving it via out own CDN.
Analytics is working via our own CDN
Code:
Request URL:http://cdn.z22se.com/js/ga/ga.js
Request Method:GET
Status Code:304 Not Modified
Request Headersview source
Accept:*/*
Accept-Charset:ISO-8859-1,utf-8;q=0.7,*;q=0.3
Accept-Encoding:gzip,deflate,sdch
Accept-Language:en,en-GB;q=0.8
Cache-Control:max-age=0
Connection:keep-alive
Host:cdn.z22se.com
If-Modified-Since:Thu, 23 May 2013 21:55:59 GMT
Referer:https://z22se.co.uk/
User-Agent:Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.31 (KHTML, like Gecko) Chrome/26.0.1410.64 Safari/537.31
Response Headersview source
Cache-Control:max-age=86400
Date:Thu, 23 May 2013 22:07:12 GMT
Expires:Fri, 24 May 2013 22:00:09 GMT
Last-Modified:Thu, 23 May 2013 21:55:59 GMT
Server:nginx
Vary:Accept-Encoding
X-Age:423
X-Cache:HIT from Backend
X-Cache:HIT
X-Edge-IP:77.243.179.43
X-Edge-Location:London, GB
This is a good comparison between the old and new servers!
The sitemap I generate for the shop. The only difference is the server (which is actually set up exactly the same software wise)
Before: 34.7 minutes
Now: 14.38 minutes
