i like you even more now lolThe coupe has all the wiring in place for the seat airbags. behind the door cards you will find a plug wrapped in plastic taped up. All you need is the door sensors and the plastic moulding they fit into. OP-COM can do the rest
well they look like this for the coupe will be the same for the 3 door but different for the 4 doorHi,
Just added seats with inbuilt airbags and getting squib errors as expected. What criteria did you use to search for the airbag modules?
I have no idea what they look like so can't compare pictures etc to make sure I get the right ones
no problem hope you have better luck with op than meThanks for the pics, annoyingly I dumped a couple of these a few months ago
Will grab a pair and see how I fair with OpCom
new one from vx will be tens of thousands heheand I bet that isn't going to be cheap??
