could be one or the other when youre going straight and hear the grinding type of noise thats the wheel bearing ive had that years back when i had a cavalier just need to check for play in the c.v. joints or the wheels you should still notice when the wheel is off and you turn by hand if its a bearing whether front or rear wheel
