I've changed it again:yeah better but it still 3 times the size of the genral tab
Yeah, it's really strange what it's doing. The weird thing is the generation of the MCE editor is the same as the XF core framework, but it's behaving strangely in the tabs. The developer is looking into it, but we should hopefully be expecting an update to XenForo on Tuesday (1.1.4) so we'll see what happens after that.Sorted... bit shorter than the general tab, but works.
Good spot! I didn't realise that option was setAny way we can change the rating system? Seems a bit silly that you can rate your own car! lol.. Give it 5 stars
I'm just looking at that now. I'll see if anything can be done, as it would be nice to have a check button that says "Cover Image" and use that one.What about image order? Anything we can do on that, be able to adjust the order of images if needed, otherwise its a long job deleting reuploading to get the latest image as the cover image :-/
lol and after i give yours 5 stars mines not even in sightThat will be why Carl's is doing so well
You know I'm only playinglol and after i give yours 5 stars mines not even in sight
https://z22se.co.uk/garage/2002-astra-sxi.3/
i know me toYou know I'm only playing
Update from the developerI've asked on the support forum: http://addons.nfljunkies.com/threads/selectable-cover-image-for-item.430/#post-2232
Bob B said:Its something that I have written down on the TODO list. I've kinda held off doing much attachment stuff waiting to find out more about xf 1.2.0 and the attachments system (if there are any planned changes). In the mean time, I've thought about tweaking what I've done and changing it from the FIRST attachment to using the LAST attachment as that would be a hell of a lot easier to swap out. But yes, the notes that I have on the white board are to make it "select-able"
Its definately a x.X.x bit of functionality.
