Gazza submitted a new resource:
Replace Door Pins (version 1.0) - Replace Door Pins
Parts needed
Small screwdriver
New door pins
Small Alan key
Time taken
Took around 30 minutes that was with taking pic’s at the same time.
Step 1
First you need to price up the plastic surround, to do this put a small headed
screwdriver under the plastic and price it up
Step 2
Price a small screwdriver behind the red plastic on the original door pin it
should pop off and allow you to pull the door pin off leaving you with a threaded
pin to fit the...
