Gazza submitted a new resource:
Remove Astra MK4 Center Console (version 1.0) - Remove Astra MK4 Center Console
PLEASE NOTE IF YOU HAVE A STANDARD HEAD UNIT MAKE SURE YOU HAVE THE CODE TO UNLOCK IT AS YOU WILL NEED TO REMOVE THE RADIO.
Tools used
Small screwdriver
Pliers
Torex screw driver
Time taken
Took me around half an hour but allow abit longer
Step 1
First you need to remove you head unit and the cage.
Step 2
With the ashtray open put your finger behind the piece of plastic around the cigarette lighter and pull it forward it should pop out very easy.(make sure you...
