Resource icon
Interior Remove Astra MK4 Center Console
Gazza
Gazza submitted a new resource:
Remove Astra MK4 Center Console (version 1.0) - Remove Astra MK4 Center Console
PLEASE NOTE IF YOU HAVE A STANDARD HEAD UNIT MAKE SURE YOU HAVE THE CODE TO UNLOCK IT AS YOU WILL NEED TO REMOVE THE RADIO.
Tools used
Small screwdriver
Pliers
Torex screw driver
Time taken
Took me around half an hour but allow abit longer
Step 1
First you need to remove you head unit and the cage.
Step 2
With the ashtray open put your finger behind the piece of plastic around the cigarette lighter and pull it forward it should pop out very easy.(make sure you...
HI Gazza
i am a new member
I was looking at your about removing Remove Astra MK4 Center Console
I used to be able to o all jobs on any car i have had - but not now
i am limited because I am partially disabled
so i need help in changing my center console
I live in Stockport,Cheshire
as a new member am i allowed to ask Questions
Are you able to help at a reasonable charge - in changing my console
can you please let know
if you not to far away i could come to you
if not can you recommend any one in or near Stockport
Regards scotlandjim
Am allowed to leave my mobile number
Scot you are better off asking if a member is near you and wiling to help in the members area local to you. I would not advise sharing your personal details on the forum but via PM.
Back
