IDI AMIN
How's the troops getting on.
I have a little dilemma with reg plate light the spade part has broken off the strip pictured i was wondering does anyone know if you can buy these parts by their self. Or is it a whole new fitting. Scrapyards are getting a little shy of vectra b's now.
The outside lens is the same for Astra F , G Zafira etc. But the internal fittings are a little different. Off of the other cars the plastic holders are shorter, so they would not sit the same behind the reg plate panel
Even the strips from other fittings are a little different the way they are shaped and the direction they go to the spade connector.
Is it a case of patch up job is it ok to solder this stuff
Looking for some suggestions.
Really need replacements for both sides as due to age other side has a similar problem
