Hi all i have a rattling engine on my vectra 2.2 direct with the z22yh engine. Thinking about changing the timing chain but not sure to balance chain as well ???
Yep balance chain was the culprit and failure of the tensioner has probably done this. Its stripped some teeth as well. Why would the tensioner failure ??. I change the oil and filter every 5000 miles.
