Well half fitted
. It was a mission removing the old one with no pins. I damaged some of my blank switch covers trying to remove the old system. I just need to order the right colour surround for my car then it should all be looking nice. I bought this system as it's not too flash looking, looks a bit standard. I also got this system as it's bluetooth for my phone while driving 8) . I won this yesterday on Ebay for £137, it came boxed with all the gear from new.
Main features
Max. Power Output MOSFET 50W x 4 .
Tuner AM/FM .
Plays CD-R, CD-RW, MP3, WMA, WAV, AAC .
Bluetooth Yes .
Display Illumination Blue OEL Display .
Button Illumination Blue .
Rotary Commander Yes .
Remote Control Included .
Cellular telephone auto muting (+) Yes .
This feature automatically reduces the volume of your system when an incoming call is detected or you dial an outgoing call on a cellular phone installed in your car. ..
Connectivity
Aux-in Yes (Rear) .
Direct Sub Drive (+) Yes .
Combine the MOSFET 50Wx4 power amp and EEQ Plus technology to get Direct Sub Drive, another unique Pioneer technology feature. It enables you to amplify your front speakers by 2 x 50 W and add a 70 W amplified filtered subwoofer (in 2 Ohm mode) in the rear to enjoy outstanding full power bass without an extra amplifier. It's an easy solution for lovers of booming bass. .
Hard-wired Remote Input Yes .
High Voltage Output (+)4V .
To provide a high output to your amplifier, Pioneer has built a special High Voltage Preamp circuit yielding no less thatn 4 V non-clipping output to the preout terminal. Such a high output voltage means the power amplifier does not have to work so hard to produce sufficient gain to give high volume levels. As a result, even a low gain power amplifier can be used, giving excellent sound quality with low noise. .
IP Bus Yes .
iPod Direct Control Yes .
RCA Preout (+)3 (F+R+S/W or NON-FAD) .
Thanks to the RCA pre-outs, it is easy to expand your sound system. You can significantly improve your in-car sound quality by connecting extra amplifiers to your headunit. You could customize your sound system with separate amplifiers for the front speakers, the rear speakers and a subwoofer. Combining Pioneer 's EEQ+ with the RCA pre-outs let you create the exact sound you want, with the focus on complete flexibility! .
Sub-display Output Yes .
USB Input Yes ..
Bluetooth
Bluetooth Ready Yes .
Handsfree Telephony Yes .
Audio Streaming Yes ..
iPod Compatibility
iPod Ready Yes, via optional cable CD-IU50 .
Compatible Generations (+) September 2005 - September 2007 .
For your ease of reference, here is a list of the iPod Generations we refer to:
Apple Product
Generation / Release Date
Firwmare version
iPhone 3G September 2008 2.0
iPhone November 2007 2.0
iPod Touch (Generation 2) September 2008 2.1.1
iPod Touch (Generation 1) September 2007 1.1.5
iPod Classic - 120GB September 2008 2.0.0
iPod Classic - 80GB, 160GB September 2007 1.1.2
iPod Nano (Generation 4) September 2008 1.0.2
iPod Nano (Generation 3) September 2007 1.1.3
iPod Nano (Generation 2) September 2006 1.3.1
iPod Nano (Generation 1) September 2005 1.3.1
iPod Video (Generation 5) October 2005 1.3.0
iPod Click Wheel (Generation 4) July 2004 1.2.1
iPod Dock Connector (Generation 3) April 2003 2.3.0
iPod Photo October 2004 -
iPod Mini January 2004 1.4.1
Notes:
* Pioneer cannot guarantee the future compatibility of our products with any iPod (or iPod firmware update) which is released after the Pioneer product release.
* The compatibility information is based on the above-mentioned firmware version.
* iPod shuffle is not supported. Only iPods with a "30-pin Dock Connector" are connectable.
Supported Functions • Battery charging
• List browsing
• Music playback (track up/down, fast foward, rewind, pause, repeat and shuffle).
Tuner Features
Radio Data System (RDS) (+) Yes .
RDS (Radio Data System) is a system for pro-viding information along with FM broadcasts. This inaudible information provides such fea-tures as program service name, program type, traffic announcement standby, automatic tuning and program type tuning, intended to aid radio listeners in finding and tuning in to a desired station. Note: • RDS service may not be provided by all stations. • RDS functions like AF (alternative frequencies search) and TA (traffic announcement standby) are only available when your radio is tuned in to an RDS station. .
Traffic Announcement Yes .
Best Stations Memory (BSM) (+) Yes .
Best Stations Memory scans and memorises the six strongest, clearest stations available on each band. .
PTY Search (+)Yes .
A PTY search is performed by program type as indicated in the PTY list (the program types are: News&Inf, Popular, Classics, Others). It also provides automatic tuning to emergency broad-casts (PTY alarm). ..
CD Player Features
MP3 Text Display Yes .
USB Text Yes .
Disc Title Memory Yes ..
Audio
Advanced Sound Retriever Yes .
ASL (Automatic Sound Leveliser) (+) Yes .
Compensating for additional outside noise, the automatic sound leveliser uses signal processing to automatically and electronically adjust the internal volume so that your music always sounds right. .
D/A Converter 1-bit .
Graphic Equaliser 7-band, with 5 preset EQ curves and 2 custom .
High Pass Filter (+) Yes .
When the subwoofer is connected and you do not want low sound to play from the front or rear speakers, turn the high pass filter on. Only fre-quencies higher than those in the selected range will be output from the front or rear speakers. .
Low Pass Filter Yes .
Loudness (+) Yes .
At low volume levels, low and high frequency sounds in music can be overpowered by ambient noise levels in the vehicle. Loudness control provides a one-button way to boost these frequencies and provide better overall sound at low volume levels. .
Source Dependent EQ memory Yes .
Source Level Adjuster (SLA) (+) Yes
Main features
Tuner AM/FM .
Bluetooth Yes .
Connectivity
Aux-in Yes (Rear) .
IP Bus Yes .
USB Input Yes ..
Bluetooth
iPod Compatibility
Apple Product
Firwmare version
Notes:
• List browsing
Tuner Features
PTY Search (+)Yes .
CD Player Features
USB Text Yes .
Audio
Loudness (+) Yes .
