Project freeze my insignia 4x4 off 2018
fuel tank cover got painted so not to rust like the last one
star silver
all the rear subframe parts came back from the powdercoaters
car is now stood under cover till ive the time to get the whole floor pan done
the work on the 2nd 4x4 has been keeping me busy :) build thread for that one coming soon
after pinching the 20" wheels for the other 4x4 i found a 2nd set of vx line 20" going cheap and only 3mile up the road
went and fetched the most of them were curbed and tyres were all odd
after getting the tyres pulled off i found one buckled and cracked
just one crack did the same procedure as the the other set thats been on the other car for a while now and done quite a few mile and the crack has not returned.
drill the end
cut the crack open to get all the gunk out so its all nice and clean for welding
new tyres came falken azenis fk510 245/35/20
on with the welding found the reason for it cracking bit of crap in the alloy it wouldn't weld had to drill it thru a then fill it up
thats better
flapy pad to make it all tidy
inside tidied up
sent them off for powdercoating and what a job they did like brand new again
had to order one more centre cap as the wheels only came with 3
bit of an update with this one
bought a shot blaster and went to work
the dog looked it over 1st lol
blaster making it easy work
some overspray from painting a minidigger took ages to get it off
grit every where
all the loose stuff gone and rest removed
had chosen to go with a raptor body colour smooth finish on the under side so used the raptor anti corrosion epoxy primer this also save a few steps of using etch primer and adhesion promoter as it does both in one step
full under side covered
the raptor mixed at 3:1 with 10% paint and 20% thinners to fire it thru a spray gun
nice finish out the gun
metallic particles came thru as well as the colour
g3 clay bar mitt removing loads more over spray from the mini digger
tryed to fit the fuel tank but the have supplyed me with 2wd straps so its on hold till i get the right ones
new heat shields and plastic retainers fitted
jet washed the chassis rails out wth drain cleaning attachment to wash out the grit once its dry i will wax oil the inside of the rails
so the tank straps
heres the difference between 2wd and 4x4
after a few days with an order from the factory the new ones turned up
back in feb i bought a used a20nft head for porting couldn't complain purchased for £90 so bit of a bonus with a stock head used coming in at around £450 :confused: but there were issues lol
dirty
listed as perfect working order but what about them 2 bent valves YO lol
bit of a clean up
almost like new
one day i will get round to fitting larger valves double springs and some cams :)
so i have finally got round to doing some work on this insignia
new tank straps painted in epoxy and black gloss 2k paint
after borrowing the cam sprockets for another car the new ones went on and the lid put back on
exterior still needs cleaning
interior has held up well for being stood for the past 18 months
wiped the dust off the tank cover and installed the tank back on the car
not an easy task when you have gained a few pounds and trying not to scratch the new paint lol
fuel filler pipe was rusty
it was needle scaled then treated with rust remover acid
having never used the rust remover before i was a bit dubious
within minutes it had pulled the rust off
leaving a nice clean grey metal to paint to
2 coats of epoxy primer to seal it up
next up was the prop shaft
it was sanded with a 320grit on the 6" da
painted over with rust remover
cleaned and dried off then coated with the same epoxy primer
2k black gloss on both the prop and fuel filler pipe
at least with the painted finish in the future if need be it can be sanded and painted to bring it to a new finish again
better than new well until i get the new boot for the end
even the rubber coupler and stainless clips were cleaned
few jobs to do im waiting on new rear hubs and disc back plates to come
ive got to replace 2 studs on the wheel well to hold the heat shields then start to clean up the haldex unit and fit the bushes to the subframe
Been and stocked up on stainless bolts thought it would be silly to put the old rusty ones back in now
Refitted the covers to the filler pipe and fitted it back to the car weathers bad so not much else getting done today
With the tank now fitted I washed the fuel lines thru with new fuel in the tank glad I did there was some rubbish in the pipe work
It also had its 1st run upto temperature in 19months after priming the oil and a few cranks it sprung into life again its surprising how quiet it was with no center section and silencers fitted
Did have a vid but it's to large to upload to the forum so some screen shots :)
some more done
rear crash bar cleaned and painted
new front wheel arch trim i pinched the orignal for the other 4x4
prop wrapped up till its needed
acid dipped the nuts for the crash bar
and now to put some paint on the subframe where the powder coaters missed
then on to fitting the new bushings quite technical on getting them in the right place
a mate lent me a tool for pulling them in its going to be something i purchase in the future great tool
anti roll bar fitted and the bushes for the haldex
wiped all the overspary off the brake pipes with thinners refitted all the clips and the new level sensor with stainless bolts
wiring clip fitted and hand brake cable wiped over and clipped in place
cleaned behind the lights and refitted them crash bar back on and gave the boot lid a polish and wax
next job paint and fit the bushes to the upper arms
had to skip fitting the subframe the lower arms need to be fitted 1st as the bolts wont go in with it on the car
more soon :)
few more steps of progress and new parts arriving
the car was covered in overspray so ive been at it agian with the clay mitt and got more off
in this image you can see the left side has the over spray and the right is clean
wheels are ready to go on
rust remover on the wish bones
covering the missed spot with epoxy primer
2k gloss black
new bolts 6 for the rear hubs and 4 of the off set bolts for the upper arms
into the box of many new parts they go
new gm wheel bearings and back plates
the rear bushing in the hub bracket are unavailable to buy individually so had 2 brand new brackets supplyed from germany new bushes included
the bolts,hubs,brackets and back plates combined
new discs and stainless bolts
the rear calipers (bit of a mess) heres why you never use hamerite it looks shat lol
stripped all parts from the calipers during clean up
the rubbers were washed in boiling water with fairy liquid. After soaking for 30mins the paint that was on them all came off and the dirt came off in the 2nd 3rd wash
bit cleaner
clean and dry and ready to go again
new discs and pads for the front 337mm discs and pads to suit the police spec twin pot calipers
conventlly i had a 2nd set of police spec calipers ready to go on this car
in need of a clean up
lower wishbone bushes are made in 2 halfs ive bought some heavy duty clamps to make them round for installation
right heres what about 3 hours of cleaning does to calipers
special type of flappy pad just for alloy made a nice job of the finish
removed the casting marks from the top edges so when there on the car its more smooth
ear plugs and energy drink can bottoms
epoxy primer
left to dry hope to get them in silver soon
some more work done over the last few days and some real progress on the whole
rear caliper brackets shot blasted
after and before
masked up ready for paint
calipers went to star silver and clear 2k lacquer
cleaned up the sliders and applied cold galvanising paint
all clean and ready for the rebuild
some time later
called up HEL performance as i was unable to find a line kit to suit the setup i have or will have
had to custom order the pipes the pipes listed for the insignia vxr were 370mm long the vxr use the same setup as the 2.0t 4x4 im sure ithe 2.0t 4x4 came 1st lol but when measuring the rear pipes on both cars they were 430mm long
the fronts listed for the ""sri"" were 515mm with m10x1.5 banjo so the front were off the shelf parts altho i will be using the twin pot police/bi turbo spec front calipers that still use the 515mm front pipes
the kit came after a days wait they were kind enough to supply me with 8 bolts just in case 4 of each m10x1 and m10x1.5 and as a bonus new pipe retaining clips in stainless i had almost bought new gm ones
ordered at the same time stainless bleed nipples
on with fitting the new bushes to the upper and lower arms there a split type so had to make a tool to get them round for pushing in
dads idea with me adding a few shells to make it the right size
this one was a b*****d but its in
all ready to go back on the subframe
subframe pieced back together so it can be refitted to the car the lower and front upper arms need to be installed 1st as you cant get the bolts in after its fitted anti roll bar kept the lower arms up
not sure if i can get the haldex in after but we shall see
back on the car loosely
new hub bracket,hub,disc shield ,spring,disc fitted
caliper back on and there's no doubting the new hel pipe is the same as the original
next up the haldex unit lets see if we cant get it looking a bit fresher than the rusty CV's
new solvent degreaser for the wash tank
new belt sander to help with the cleaning of rusty bits
cleaning of the haldex unit
into the wash tank
primer
aluminium paint
and a coat of laquer
and then on to cleaning up the drive shafts
after getting all the rust of and down to clean bear metal the outer cv was painted with epoxy primer
knocked the cv off and stripped to clean out the grease
all parts in the wash tank
painted with alu look paint and laquer
washed out the inner cv ready but had to buy the grese special its not moly due to being tripod
cv rebuilding
acid
same alu paint and lacquer
gloss black on the shaft
much improved
other shaft prepped
painted some of the bits on the haldex black so its not just all the same colour underneath the car
mounts and the hydraulic pump in gloss black and the prop shaft hub
polished the controller cover then gave it a coat of laquer
hydraulic lines for the Elsd clutch painted to stop any more corrosion
black as the final colour
haldex unit bolted back in
nice and clean looking now
caliper handbrake levers shot blasted and painted black
next up the shocks sanded and acid wash
big update and work covered over the holiday period :)
pictures in order to continue on from the last post
shocker covers cleaned up
2k paint on the shock body
had to order the grease for the inner CV joints
hand brake levers back on the calipers
fixed the broken wheel speed sensor
coming together now
other side to
after cleaning the outer cv on the drivers side i found the cage cracked must of missed getting it off with the hammer
warming up the waxoil
all the cavities done that i could get to
bungs back in and bracket for the arch liner riveted back on
looking something like
new GKN cv from germany :confused:
lick of paint
rebuilt and ready to go back on
diff oil changed
and finally wheels on and back on the ground
needs a good clean
went at the overspray on the roof and drivers side with the clay mitt
stock on stainless bits and bobs E clips for the hand brake cables and nuts with inbuilt washers for the caliper levers
the 2 side by side
front boot was split on the prop shaft and a replacement was £64
fixed it for the time being with a £6 rubber cv boot
The Exhaust..
after looking for a stainless solution of an exhaust system i had chosen to make my own with the bought ones available coming in at £600-900 and looked like they were put together blindfolded
the parts...
2x 10"x12" center exit side entry back boxs
2m of 2.5" tube
1m of 3" tube
2m of 3" tube
45* and 90* 2.5" mandrel bends 2 of each
nad something ive never done before PIE cuts
mocking up the step in the pipe
hanger made from 1/2 stainless bar
the angle and shape of the back boxs look to be a pain
making the Y connection
size of the entrance had to be adjusted to suit the 3" main pipe to the 2.5" bends
thats the hard bit over with lol
purging the pipes with argon while welding made the backs of the welds nice and clean
test fit
had to weld on a new stud for the heat shields bit of a patch repair on the raptor
new heat shields and plastic clips fitted
hangers made and bent for the rear boxs
measured up and tacked in place
looks like there may even be enough pipe for the front pipe altho i will have to buy a sports cat and get a flange made
welded the 2m length to the rear section and test fitted again
mocking up and test fitting the connection to the rer boxs
other side the same
nice and tidy looking :)
so far the above parts have cost me £255 this pic is of a reputable firms £900 version for a vxr....
yeah i'll stick with mine :)
Good work Carl.
the vxr one looks worse than the 3" one i had made by a "reputable" company. It fell apart quick and no warranty :(
well its taken me a few days to get it all sorted but its made the way i wanted it to be and not just bung and fit for £900 i would want something like i have made but gold plated :)
went and got some bits for the tig welder wanted to try the conversion tip with the larger shroud was hoping to get a pyrex cup but they didnt stock them the dronco metal polishing pads are great
the back end of the pipes after the axle i wanted polished so when its seen from the rear it looks good
purging with argon works great
back boxs went on
2 of the rubbers for the boxs have separated from the metal but there a right silly price for the 2 rubbers in the frame
found a pic of the astra j vxr rear rubber on cs webpage and the part number on the rubber matches the insignias so ive ordered one powerflex replacement to see if it fits
v band installed at the front
the hanger bars needs some fine adjustment with a lump hammer after welding
well it fits just need to decide on tail pipes
so where was i lol
new powerflex rubbers for the exhaust
cut some 2.5" for the tail pipes
borrowed the tips from the police car
washed all the tar off with thinners and then buffed the tips
rear section complete
had to make and adapter to connect the new to old
more rubbers came in the post
bumper refitted and new number plate on
new mud flaps fitted
swapped the grills back over
went for an mot a passed
started on cleaning up the paint work
intermittent AFL fault narrowed down to a relay in the fuse box
inside had a wipe down vac and new mats
last batch of new parts from my local parts
new sports cat from demon tweeks only one they had that was 200cell was 2.5"
soon fixed that lol
time to clean up the 337mm twinpot calipers
phenolic pistons
seized slider
after and before the shot blast cabinet
disc shield to suit the 337mm discs
padded the main surface flat then primed with epoxy
both prepared the same
all the gubbins washed and clean read for reuse so i thought
same star silver and clear lacquer as the rears
new hel lines and stainless nipple
had a problem with one of the pistons getting damaged so bought 2 new metal ones
all ready to go on with new trw pads and clips
new back plates from the factory
2 new wheel bearings
had some flanges made for the cat pipe
the after math of the boot clip comming off on the way to the mot lol
previous owners super glued the vxr trims on upside down took ages to razor blade it down flat
padded the area with 1000,2000,3000,4000
new pad and new bottle of g3
buffed and trim fitted the right way up no super glue! lol
did move on to the bonnet only got the rest of the car to do in g3
