Project freeze my insignia 4x4 off 2018
so sunday i sold the 2.0t signum and found a replacement after just one day lol
it looks like this :)
not sure on the black grill atm and i need to fix the auto main beam/afl in the passenger headlight
60k on the clock came with a free engine management light
it also has one of these :)
whats that at on the boot lid :)
they are a sweet engine, just keep an eye on the vvt solenoids, the metal mesh can block up and stop them working - easy to remove, one bolt and they pull out.
funny you should say that vocky i bought the car with p0013 cam phaser malfunction :)
had a mess today after replacing the high beam bulbs in efforts to get the afl error away what a pain found the trick way to do it lol
p0013 dtc set
confirmed its failed 1Mohm
the inlet one is 13ohm
ive already ordered 2 new solenoids picked up new wiper blades 5l of oil a new filter, gearbox oil , 50/50 mix long life coolant
next thing is to get the headlamp error gone, by replacing the bulbs ive now got the side illumination when turning the wheel left or right but no main beam.
ive managed to get the b1325 to clear and stay off but now its just the b0985
new oil and filter in and new coolant in today no sign of the cam solenoids van man must not like the snow also need to get a new d1s bulb for the front light its gone purple lol
#10
also sprockets have a locating pin, so only go in one position.
The a20nft chain kit is quite cheap because it does not come with the cam sprockets
going to make a tool to hold them still while undoing the bolts dont want to damage the internal springs only got the one set of sprockets lol
what a silly place to put the afl control unit :confused:
its behind the fuse box and that big bit of loom on the left
next line of attack on the lights change the afl control unit
before with that stupid painted trim
and after with removing the plastic insert on the black trim to fit it to the chrome one its looking much better
1st proper wash :)
soon be clean
picked up the new chains and the new cam bolts the bolts were £1.38 each from vx lol
even got a replacement AFL controller but it didn't fix the afl error
#18
B0985 - https://workshop-manuals.com/vauxha..._procedures/miscellaneous/dtc_b0984_or_b0985/
https://workshop-manuals.com/vauxhall/astra-j/body_systems/lighting/diagnostic_information_and_procedures/miscellaneous/dtc_b0984_or_b0985/
Circuit/System Testing
1. Ignition OFF, disconnect the harness connector at the appropriate headlamp assembly.
2. Test for less than 5 Ω between the ground circuit terminal 1, 8 and ground.
⇒ If greater than the specified range, test the ground circuit for an open/high resistance.
3. Ignition ON, connect a test lamp between the ignition circuit terminal 6 and ground. The test lamp should illuminate.
⇒ If the test lamp does not illuminate, test the ignition circuit for a short to ground or an open/high resistance.
4. If all circuits test normal, replace the appropriate headlamp assembly. Verify that the DTC do not reset.
⇒ If the DTC resets, replace the K28 Headlamp Leveling Control Module.
simmler procedure for the insignia my man on the inside printed the checking procedure for me and i already done the testing and replaced the k28 just need to go and get it calibrated im hoping thats it the up and down shutter control are not in the same place so hoping the recalibration sorts it
WP_20180311_08_11_10_Pro.jpg WP_20180311_08_11_18_Pro.jpg WP_20180311_08_11_38_Pro.jpg
