So it rolls the edge all the way up like a door skin over the frame?
Give you 10/15mm clearance?
you got it
almost the same but you have to stretch the metal in to place
it says heat the paint with a heat gun to stop it cracking lol that was an impossibility as soon as the roller touched the arch all the loose paint fell off
its about 10mm but it will save the cutting of the tire wall now the 225/35/18's are on and I will beable to load the boot up and not catch
the other side is done now
the loose paint has been sanded and all the bare metal treated with fertan
once the fertan is dry I have to replace the seam sealer and apply a rustproofing paint and then recoat with shutz
then paint the lip the same color as the car and lacquer it all to seal it
lots of work ahead
