Vectra C Power steering pump
Discussion in 'Part Numbers' started by nighthunter, January 8, 2018.
  1. Hi everybody.
    On my Vec C Z22SE/AT5 the power steering pump has stopped working. There is a unit with rectangular shaped oil tank and white connectors. I have a spare pump, wich is fully woking, also has the rectangular shaped oil tank but the connectors are black. Could this pump be swapped for the black one?
    Best regards
    Igor
  2. if it has a electric pump like the zafira mk1 I would check the fuse first mine packed up and the fuse just needed cleaning
  3. It is this type:
    It has faulty oil temperature sensor. It works for about 1minute and then goes off with DTC Oil temperature too high, but the oil is still cold. So i think it will the pump. Fuses seems to be OK. (Did you mean the High power pump for the motor, or the lower fuse for the control circuitry?
  4. on the zafira It was a 60 amp fuse under the bonnet
Matched Content
