Selling this as I have upgraded to a top spec Pioneer single din unit. I have a Vectra C surround with it if you have a Vectra C. This unit comes boxed with remote, cd, manuals, mic, fixing cage and surround. £160 - £170 with postage. Thanks
Double-Din Bluetooth Tuner with USB-in and iPod Direct Control
Double the size; many times the entertainment.
Play, talk, listen. The double-din (which means it fits into a size twice that of a normal car radio) FH-P80BT is your communication and entertainment hub.
Make and receive calls wirelessly, as well as stream music: the FH-P80BT supports both ‘hands-free’ and ‘audio’ profiles from your mobile phone. This means that you don’t need any additional in-car kits, cradles, wires or headsets.
The FH-P80BT will play your entire music collection as well, supporting every audio file format. Hook up your iPod, USB music source or portable audio player, and control them directly from the CD Tuner.
You can control this CD Tuner with its ‘Rotary Commander’, which works very much like a joystick - essential for navigating through your WMA, MP3 and iTunes audio files.
The FH-P80BT also has 3 RCA pre-outs, so you can boost your in-car set-up with additional amplifiers, subwoofers and speakers.
Whichever audio format you play, and however you build your in-car setup, you can be assured of high quality, pure audio, customised to your needs. The FH-P80BT has a 7-band graphic equaliser which you can use to best match the equalisation levels to the acoustics of your car.
Main features FH-P80BT
Max. Power Output MOSFET 50W x 4
Tuner AM/FM
Plays CD-R, CD-RW, MP3, WMA, WAV, AAC
Bluetooth ready
Display Illumination Blue OEL Display
Button Illumination Blue
Rotary Commander
Remote Control Included
Cellular telephone auto muting
Connectivity FH-P80BT
Aux-in on rear
iPod Direct Control (with optional USB-IPOD CABLE)
USB Input on rear of unit
IP Bus (for CD Changer)
RCA Preout 3 (F+R+S/W or NON-FAD)
Sub-display Output (additional adaptors required)
Hard-wired Remote Input (additional adaptors required)
Direct Sub Drive
High Voltage Output 4V
Bluetooth FH-P80BT
Handsfree Telephony
Audio Streaming
iPod Compatibility FH-P80BT
Requires additional USB-IPOD CABLE
Battery charging Yes, on all generations from September 2005 - September 2007
List Browsing Yes, on all generations from September 2005 - September 2007
Music Playback Yes, on all generations from September 2005 - September 2007
Tuner Features FH-P80BT
Radio Data System (RDS)
Traffic Announcement
Best Stations Memory (BSM)
Preset Channel Memory 24
PTY Search
CD Player Features FH-P80BT
CD-R/RW Playback
MP3 / WAV
Windows Media Audio (WMA)
iTunes AAC Playback
MP3 Text Display
USB Text
Disc Title Memory
D/A Converter 1-bit
Audio FH-P80BT
Loudness
Low Pass Filter
High Pass Filter
Graphic Equaliser 7-band, with 5 preset EQ curves and 2 custom
Source Dependent EQ memory
ASL (Automatic Sound Leveliser)
Advanced Sound Retriever
Source Level Adjuster (SLA)
Tuner AM/FM
Bluetooth ready
Rotary Commander
Aux-in on rear
Direct Sub Drive
Bluetooth FH-P80BT
Handsfree Telephony
Audio Streaming
PTY Search
CD-R/RW Playback
MP3 / WAV
iTunes AAC Playback
MP3 Text Display
USB Text
Disc Title Memory
D/A Converter 1-bit
Audio FH-P80BT
Loudness
Low Pass Filter
High Pass Filter
