Peoples thoughts on this breather mod
shame the engines not lower you could fit a filter breather cap and save the effort of the above
dewismotorsport
I could potentially weld 90 degree pipes on so they hang over back of engine.
I've seen some of the vx220 efforts of running a filter off the filler cap but I'm not convinced 100%
dewismotorsport
Right I've done some serious Internet reading on this, plan is this:
Mod filler cap either like below but run pipe round to my catch tank
ai693.photobucket.com_albums_vv292_dewismotorsport_83142291_4D0c044cd30b7d3fb01bac21563975cdf5.jpg
Or buy this and get a 90 degree coming off it and back to catch tank
http://www.metcomotorsports.com/proddetail.asp?prod=MBR0003-10AN
And then modify the blank with a M22x1.5 dash fitting and run pipe up to catch tank, or just drill out a old blank and weld a pipe to it and run back to catch tank
ai693.photobucket.com_albums_vv292_dewismotorsport_C65B8A81_B7c916c9863a30a7ec3033281b18d2eb24.jpg
Will test both at Bedford on the 28th of feb and report back
I know its slightly off topic but anyone got any ideas about the breather/vacuum pipe on the front of the rocker cover.
I need to get a pipe from there to the turbo at the back?
On the net rocker cover its on the back.
dewismotorsport
Cheers Carl, them holes in filler cap look tiny, I think I'm gonna leave the cam cover alone for now and just mod the cap and observation blank. I have read about's adding a hose pre tb but want to avoid any chance of oil vapoured air going back through engine if possible.
That's good to know Vocky thanks, I know people are only seeing these problems on track so want to give the engine the best chance before trackday.
TFD
I think it's possible to just get an atmospheric breather (pcv between runner 2 and 3 closed):
Camcover -> Hose -> Catchcan+breather.
You only have problems with positive cranckpressure so you need an escape for the pressure.
Technicly I don't think you have to make a connection to the intake manifold or intake pipe for suction.
Any thoughts on this? Am I right or wrong?
but thats what i meant and that's what a catch tank is for
rocker cover>catch tank>air filter :)
corsaZ22se
mines been fine using the pcv in the manifold as standard sc with just a breather on the cam cover.
will put this in to a catch tank soon to keep it legal for road use.
laminova cores are free from oil in mine, no sign of oil in manifold.
the last n/a engine I built on bodies had a catch tank, cam breather > catch tank > vent filter (not inlet filters)
not sure of the date but modern cars are not allowed to vent crank case breather fumes to atmosphere where as older cars did. they just had a pipe from rocker cover running down the side of the engine.
dewismotorsport
Problem is road and track are two totally different animals. Road use you will never see a problem but on track where it's held almost continually at WOT it becomes a problem and end up getting blow by if not treated.
I 100% don't want oil vapour going back through system as its taking away from clean oxygen rich air so is no good for combustion.
The vx220 boys have reported problems both with the pcv open and closed so I'm trying to fix a potential future problem before I get on track (y)
