Pathetic throttle response - Causes & solutions
Berto
This ridiculous (and dangerous) 'throttle lag':
... seems to be caused by the slooooow rotational speed of the throttle blade below ~3000 rpm:
Apparently the joke is deliberate and supposed to be a 'feature' of the 'throttle-by-wire' crap
. Like Windows 10, embrace progress to run backwards.
That's unbearable and makes the car undriveable. Furthermore, sabotaging the VX220 / Speedsters with this prank should be regarded as a crime against humanity.
Looks like our american cousins were similarly 'blessed' on their L61 version of the engine. But this guy managed to solve it
Tuning your L61/LAP/LE5 for better throttle response
ai205_photobucket_com_albums_bb54_supernovanator_Throttleopeni69e529ba11c64d8e01552a375d15328d.png
ai205_photobucket_com_albums_bb54_supernovanator_Throttleopeniae853ee114a8ebe6e6cfd17f9d952210.png
After changing the numbers in his 'Throttle Area Increase Rate' table, he gets a real throttle response at last
This other video explains the problem on the Z22SE, and apparently also manages to solve it:
^ It's some software demo from six years ago.
So we just need to change some frigging numbers in the ECU throttle table.
How could we do this?
What do we need in terms of software and hardware?
as of a few year back you could get a app plugin device that made the throttle response better but not sure if its suited to the z22se ecu
like this
https://www.pedalcommander.com/
Berto
... getting the Dutch software from Peter is really the only option
You are referring to this, ain't you?: ObdTuner
"... With OBD tuner it is possible to turn the Z22SE Engine Control Unit (ECU) into a free programmable ECU ..."
"... you only need a laptop/PC running Windows (XP/ Vista/ Windows7) and a low cost OBD interface ..."
^ On first impression sounds like heaven to me!
Downloading and scrutinizing it ASAP.
like this
^ Those gadgets just boost the voltage signal from the throttle pedal potentiometer/s, to trick the ECU into thinking that you're depressing the pedal more than what you're actually doing. Then they charge you a couple hundred for what really costs about the same in materials as the EGR cheater (a few quids at most).
Problem is the OEM throttle table in the Z22SE ECU doesn't give a f**k about how briskly we plant our right foot, and just slowly opens throttle plate at its leisure pace, ignoring pedal signal (boosted or not)
. My bet is that this renders "pedal overclocking" useless and that none of these gadgets really works on the Z22SE.
Berto
I solved the 'dead spot' in my throttle pedal by adjusting its play.
1) Make sure contact is OFF.
2) Completely unscrew 'A', then just loose (not remove) '1' to '4'.
3) Now rotate/pivot the whole plastic cover towards the bulkhead (front of car) to get rid of the dead spot.
4) Tighten screws '1' to '4', and screw 'A'.
5) Enjoy real throttle response.
Provided enough amounts of swearing, this can be done with the throttle pedal in position and plugged.
#12
I tried it, just made it rev higher and it began 'hunting'. ended up putting it back to normal. was a twat to do on the car though! maybe I did ut wrong though
#13
Use a DTUK PedalBox. Three adjustable throttle maps. Plugs straight to the pedal. Far less intrusive and takes seconds to fit. Had them on all of my cars for the last few years. Need to get one on my G
#15
I have never found any problems with throttle response on the z22se, been running 1 for 17 years now.
not as snappy as a cable throttle and never will be especially on shut down times.
Best advise i was given by a main dealer and another tuning company at the start of my z22se journey was to only use 99 octane fuel, cost more per litre but gives better mpg's and still works out slightly better £/mile. the car just seems happier on that over regular fuel.
