These are usually sold as complete assemblies including the ABS ring. Just keep in mind that OEM GM numbers can vary slightly depending on whether it's the 1.8 Ecotec or the 2.2 (Z22SE) engine, so double-checking against your specific VIN or engine code is always a good idea if you need the original GM part number.
