Opel Astra G Bertone - thermostat's location.
Discussion in 'Car Discussion' started by AsDDsA, March 17, 2018.
  1. Hello. I might now ask a silly question but I really can't find where the thermostat is in Z22SE, Bertone 2.2. Is is really somewhere "deeper" on the left side of the engine? And am I able to change it on my own or should I rather get someone to do it for me?
    [​IMG]
  2. hi pal its at the back of engine ,take your engine cover off look down the back of your engine ,under the exhaust manifold is a pipe coming from your water pump follow it to the thermostat housing its on the thermostat housing , connected to your radiator pipe, remove radiator pipe then theres a couple of m6 bolts (10 mm spanner ) , undo bolts remove old one , put new one back in , bolt it up ,,,, easy pal,,
  3. Just here, over bell housing.
    like figo126 says its easy to change :)
    Photo0339_LI.
    • Like Like x 1
  4. Is it really that simple without taking out the whole enginge? :D I will try today or tomorrow and tell how it went.
    • Like Like x 2
