OpCom China Clone
Discussion in 'Car Discussion' started by Fordy, February 12, 2018 at 10:49 AM.
  1. I purchased the china clone OpCom interface and software a while back but some of the config files for the Z22SE are missing, which is stopping me from disabling the aircon.
    Does anyone have the software that they don't mind sharing or have a link so I can download it?
    Many Thanks,
    Shaun
  2. there is no need to disable the air con when its off there is no intervention
    mk4 astra needs the pressure switch left in plugged in and the ac fan resistor plugged in for the cooling module on the 2002>
    there's a lot of files missing with opcom even if there there most of them don't function
  3. problem is the previous main rad had a leak and having no intentions of using the AC, I replaced with a non AC rad, therefore I no longer have an AC fan resistor (rad was binned) and the AC pump has been removed. The intention was to just disable it with OpCom.
    Since removing, the main cooling fan is constantly on.
  4. needs the pressure switch left in and the resistor to keep the system happy on a mk4 astra
  5. Anyone got a spare AC fan resistor?
  6. cheers for your help mate.
  7. Think I will just get a second hand radiator with AC rad and fan
Matched Content
