I figured it best to start a new thread rather than hijack someone else's (apologies if this was the wrong choice!).
I've had my z22se powered Vectra B for 11 months. It had an LPG conversion already fitted when I bought it.
Not long after I got it, I noticed that the temp needle was off the bottom of the scale regularly. I tracked it down to a dodgy thermostat, so it was over-cooling on the motorway, and only coming up to full temp on slower roads. I took it in to be repaired, and they discovered that there was no thermostat at all! They fitted a generic one (rather than a Vauxhall part), since the engine had clearly already been modified to bypass the the missing thermostat... they they just popped a standard unit back into the pipework.
Since then, the car has been doing better miles par gallon (as I expected), since the engine is now running at the correct temperature. However, I've also noticed that the car is consuming much more oil and my dad said he'd be suspicious as to why the thermostat had been removed in the first place (with hindsight they look to wise words).
Come the winter, I also noticed that the coolant was very low (took about 2½ litres to top up). Been having to regularly top it up since then. Last time I refilled it, I noticed oil in there too, so stopped driving it and booked it into the garage.
They thought it sounded like the head gasket, but then changed their minds and did some pressure tests, and found some water leaks which they fixed. They flushed the coolant until running clean again gave it a final pressure test, then gave the car back. I've driven it for two days, and then thought I should check the coolant to be sure. It was full of oil!!! So my coolant looks like a gun metal grey colour. I checked the oil filler too, and there is a bit of cream and water drops, but that could be condensation or leaked coolant!
So I've spoken to the garage again and they still don't think it is head gasket, more suspecting there might be a leak in the oil cooler... although they said they need to speak to their expert and get back to me tomorrow. So I'm seeking some other opinions here.
It drives totally fine. No loss of power or judderyness.
I suspect that the problem only shows itself when the engine gets hot, and that a disreputable garage has removed the thermostat to disguise the problem before I bought it, which was of course reversed when I got the thermostat refitted. I think the coolant leak (which they fixed last week) compounded the problem and accelerated the coolant loss.
Does this sound like the head gasket? Oil cooler leak (if this engine has such a thing)?
Anyone recommend an expert garage on these engines near Hertford, Hertfordshire, who know what they are talking about but don't cost the earth?
Thanks for reading.
Mike
ps apologies if I wrote too much... or if I missed anything important out! If you need more info just ask.
Thanks for reading.
Mike
