SriSte
Found this on an 'S' reg 1.4 VW Polo
Its a thermostat housing blanking plug, its clipped into it in the same way as the EGR pipe is clipped into the inlet manifold on a z22se.
You can see where I had to file the plastic so I could get the clip in, its a tight fit.
I should have taken a picture of the end, its solid plastic and doesnt protrude into the inlet tract at all.
I did have a go with 2ps and 10ps but never did like how they fit notsure.gif
I swapped the sealing ring over from the egr pipe because its maybe 1mm thinner and fits better.
All good, hope this is of use to some of you cheers..
Ste
Ste
