garethg12345
Hi,
i have a astra G 2001 2.2 bertone Z22SE
when i bought the car it had an intermitent fault being,
speedo would work then stop also the odometer when this happened
the MIL, ABS, TC lights would come on happened the previous owner
said he had replaced the speed sensor but did not clear the faults he mentioned he
suspected a bad connection with the abs pump connector block
but now the fault are constant,
has anyone had any similar problems or knows how to go about eliminating the faults
on the scanner the code is P0502 - Vehicle Speed Sensor Low Input
help would greatly be appreciated
gareth
gareth
