corsaZ22se
have you left the earth wire off near the egr valve?
Is that the green thing that look like material?have you left the earth wire off near the egr valve?
most likely the oil leak is coming from the blanking plate of the auxillary take off - the alloy plate used to seal the end of the inlet cam. Common oil leak problem, just clean all the oil and use engine sealant and refit.
Going to attempt the front brake pads this afternoon, is there anything inpaticular I should know before I start?
My zafira has an oil leak that looks like its coming from behind the starter motor. Is this likely to be the auxilliary take off plate as you mention above? If so, how do you get to this - what needs to come off and can it be done with the engine in the car? Any help gratefully received!
as you can see from the above picture, just two bolts hold it on, very easy ten minute job.
