Anthony372
Hi,
Newbie on here so any help would be really appreciated.
I had a compression problem where i only had about 125psi on each cylinder which did not alter with light oil put down the spark plug area.
As a result, I have just fitted new inlet and outlet valves to my z22se. Also renewed the head gasket and bolts.
Lightly lapped the valves with fine paste until a dull ring appeared and the pistons look in good condition.
Now it is all back together, i took it for a run down the road. The road behind me seemed to be replaced with white smoke.
Do i just need to let it settle or have i done something wrong?
Thanks in advance
Thanks in advance
