White estate
Ok i know this isn't a 2.2se engined Astra but I'm after some advice ?
After bouncing a few messages back and fore to EvoCarlos i took his advice after fitting vxr rear hubs he advised me to disconnect ads sensors to rear and then try the brakes but its still locking the rear brakes before the fronts.
As the Van did have drums and abs i have a funny feeling the abs ecu applies more pressure to the rear than is needed for the new disc setup
Even with the abs light on surely it still should not lock the rears.
Ive got a 2.2se abs block and abs ecu which is non esp that I'm going to try to fit as the van abs block has less solenoids in it due to not having t/c so i may also need to rewire the abs multi plug hopefully not.
Just hope someone has had a similar issue on doing a disc conversion ?
