Had the MOT done this morning. Passed with advisory on rear tyres down to 3mm tread (only swapped them from the front last month, so not worried about that), and CV boot on the NS has a tiny split in it.
lol i cant never do that sit there with others its even more scary than i am lol
i always go and get a butchers at the under side just so see if theres anything that can be put on the list of todo's lol
One of the rears is down to 3mm, and the other is down to 4mm. Both fronts have 5mm left. I only rotated from to back the other week, so I'm not that fussed, as they had been on the front for 2 years.
