Ok, well been playing with the car this afternoon and have faults listed as:
- radio doesn't work
- glovebox doesn't shut
- everything squeaks
- squeal from something to do with wheels (not in time with engine revs but is in time with car speed)
- spanner light
- coolant light
- handbrake light
- seatbelt light
- airbag light
- auto adjust xenon light fault
- petrol light
- sloppy gearstick
-crack in front splitter
- driver side speaker cover missing
Think that's it for starters.
It looks like this...
which my missus and I think is alright really.
First off, took off driver side front wheel and found that the backplate was rubbing on the disk. Moved away with a flat screwdriver and squeal number 1 fixed.
Took out radio to inspect harness and found the Ariel cable missing. Hunted around and was down in the cavity behind the radio housing. Plugged it in and radio works. Pretty please with myself at this point.
Next up, sloppy gearstick. Removed the gator but not much movement from the ball joint. Popped the bonnet and looked at the linkage, pretty worn and crappy. I don't know what the proper name for this assembly is, any ideas?
It's the mechanical link that the cables push fit onto. there is play on pretty much all directions. Main issue i think is that this pin has worn the hole that it sits in, and now there is movement everywhere.
decided to choc the gap below the assembly with half a raw plug. Size 6 raw plug was good, but still some movement, 10 was too big and didn't fit. 8 was spot on. Nice tight gearstick again! Well happy.
Before...
after... Note the brown bit sticking out
Next up, spanner light. Looked at the battery and whoever had this car last must have been running a sub off of the battery, and there was a squashed 1mm cable clamped between the positive terminal and clamp, but no termination on it and was just floating around! What's worse, the positive connetion wasnt even done up! It was just placed there!!! Took it off, removed the scrap if cable and refitted. The clamp wouldn't tighten though, found the nut was almost complete threadless where it had clearly been overtightened before. Replaced the nut for a shiny new one and much better now.
Spanner light still on though. Checked every single fuse in all 3 fuseboxes but all ok. Started to rain so stopped for a fag break.
Decided to leave the spanner issue and look at the glove box. It's missing the two bolts in the bottom so is hanging low and the clip won't clip.
Hunt around the garage for two off m5 (I guess) bolts. Bolts found and glovebox off but the existing assembly turned out t be broken
The whole thing looks plastic riveted in place and I have no idea how to replace it. Modification route needed. Off to find wood, wood screws and a drill...
Lots of swearing, cutting to size, pilot drilling and more swearing, and finally got the wood in the right places and secure.
Back together, glove box sweet as a nut.
Next, the auto adjust lights. Googled it and apparently there's a sensor on the rear axle. Only found one sensor on the back but seemed tight and not wet, so looked at the front. This cable was dangling, and the ball end thingy in front of the passenger wishbone isn't connected to anything! Can anyone help here? What is it and where sgou it go?
Sensor
Dangly ball/socket connection
Taped up the sensor onto the top of the wishbone and auto adjust fault light has cleared, but not sure why. Made the mistake of fiddling with the back axle sensor, front ones and loom bits so not sure want it appears to work now, but haven't replaced anything.
Coolant is leaking from what looks like the water pump or thermostat (Bollocks
). That's for another day now tho.
Reasonable start, still need to work out the spanner issue and coolant leak issue. Brake fluid needs a top up so that will sort the handbrake light, guess the seats are non standard so need tech2 to reset the airbag and seatbelt lights?
All guidance and advice appreciated!
Also, not sure whether this should be in projects or another section now, not
introductions. Sorry if wrong moderators
Rick
