IsaacZ22
Hello colleagues, I needed information about how the behavior of my Astra 2.2 will be, if I increase the diameter of the front stabilizer bar.
The stabilizer bar of my astra g 2.2 is 18 mm and I got the stabilizer bar of an astra h 1.9 cdti of 22 mm. As I understand it, increasing the thickness of the stabilizer bar will increase the stability but decrease the grip. I have to say that I am waiting for the rear bridge of an astra h 1.9 cdti (590 NM vs 260 Nm OEM)
What do you recommend? Would the stabilizer of 22 with the rear axle of the mk5 be a good combination?
What do you recommend in the settings in the suspension geometry?
