The theme on a mobile is a full version of the theme, it just shrinks and moves the menus about. Can you do a screen shot of what you are seeing or having problems with please?
OK, so just in case, I've duplicated the default theme, and made it none-responsive, so it will display the full site on all devices. You can select this from the bottom of the forum, via the Style Chooser.
