vented rears are so 2 year agoIm going 302s on the front soon. N vented on the rear
Hi Milo, it could be worth checking the two purple relays which sit in the rectangular fuse/relay box located on top of the ABS unit. One of them is for fuel and the other engine management (not sure which one is which). Remove them one at a time, they can be rather stiff, and smear some vaseline on the terminals and replace.
Not saying this is your problem but they're worth checking.
Think you can get the map sensor from usa for like 40usd its not used in any uk cars so its an import job I would have to look up the number its been awhile since I last dug it out
I also have the code p1516. but only if I let it go through bulb check before starting.
strange thing is that even with the code live/active it can be cleared and doesn't come back until next time you go through bulb check. swapped many parts, checked all the plugs, earths ect. and all I can put it down to is to much resistance in the wiring in the corsa, the fault has been there since I fitted the z22se. didn't have the fault in the Vectra before.
seen similar faults on machines before and adding a second power supply to the controller and better earths helped so this will be my next step when I get around to it.
too much power being drawn through 1 circuit can lead to a drop in voltage enough to trigger the fault codes we have.
