Mil light on
#11
At when does the z22se engines fan kick in .looking at the temp gauge it's never gone over the half way mark .my fan doesn't work and worries me.at the minute I've had to unclip the wire off the aircon pressure sensor so the fan kicks in to protect it
#12
Fans usually cut in at 3 stages, 92*C is the first stage.
front AC fan comes on when AC is on and there's a second speed for both fans at a higher temperature. not sure what this is.
Could be worth you connecting your fans one at a time direct to the battery to see if they both work at both speeds? low speed fails first and common on any car for the resistor coil to cause this. motors can also fail, main cooling fan motor does more work than AC one so usually goes first.
