Ok not been on for a while needed some time off my car as it was wrecking my head, got back on it today and it still wrecks my head.
I've got a horrible stering wheel vibration above 60 when braking and when braking at very slow speed like pulling up it feel like abs in slow motion the car is jerking when braking.
This has started when I replaced the discs and pads and I cannot find the issue the things I've done so far are
Isolated it to osf wheel by clamping it off with molgrips then problem goes,
I've got new braided lines to go on so wasn't bothered about clamping old hose
I've checked runout at top and bottom of disc on both sides carnt check middle due to them been groved, runout is fine
Had a bit of play in bearing so fitted a new one,
Calipers are refurbed and compleatly free
When I spin wheel the disc has a slight tight spot but no idea why,
Don't no if a week caliper Spring could have anything to do with it
Any help would be apretiated cheers
