Marty's Z22SE Rebuild
Marty64
Joined
December 28, 2013
Messages
191
TY Vocky (y) i keep it for astra. Will look for a better clutch in futur.
Marty64
Joined
December 28, 2013
Messages
191
Keep cleaning... ...pfffff hate burned oil :rage:
Crankshaft case before/after:
a1.bp.blogspot.com__KYYkoYBeLx4_VSLAZgLg69I_AAAAAAAAAQo_ZHU_wJIPLUw_s1600_P2150200.JPG a3.bp.blogspot.com__wjI2mfeLtsc_VSLAuxk5E6I_AAAAAAAAAQw__PVbIxnNKy0_s1600_P4060219.JPG
Cylinder Head before/after:
a1.bp.blogspot.com__qfbNaiwt14g_VSLCdqj1yBI_AAAAAAAAAQ8_e5N__JLaJNk_s1600_P2140207.JPGa1.bp.blogspot.com__QMGQOTRTV78_VSLCmLhHaFI_AAAAAAAAARE_b5Y2hvBNFKA_s1600_P3080198.JPG
Timing housing before/after:
a3.bp.blogspot.com__bxIBSsyOlMc_VSLF0iL0ZCI_AAAAAAAAARg_v4m_97l4QhQ_s1600_P2150199.JPGa1.bp.blogspot.com__uyR_rjX_tPI_VSLFfXuGWuI_AAAAAAAAARY_dX8PBSBD3O8_s1600_P4060219_2B_2_.JPG
Marty64
Joined
December 28, 2013
Messages
191
Another Week-end to eat burned oil with the most burned parts :mad:
Oil sump before/after:
a3.bp.blogspot.com__QdnrC1XsOYo_VSl5Tw5Um_I_AAAAAAAAASA_dAetM4iiRxI_s1600_P4110220.JPG
a1.bp.blogspot.com__CUPtCxGZY18_VSl5US_YLWI_AAAAAAAAASE_dP98Jdjx7QM_s1600_P4110227.JPG
Oil pump before/after:
a2.bp.blogspot.com__EZC8ye5D9mE_VSl6t4tzwHI_AAAAAAAAAS0_atyOd2pHZxw_s1600_P4110222.JPG
a1.bp.blogspot.com__QubIGV0UIEQ_VSl7PF_yBeI_AAAAAAAAAS8_x7gIu9JbH5Y_s1600_P4110229.JPG
Cams Cover before/after:
a3.bp.blogspot.com__qJGd2rnNS7I_VSl6rV3W2FI_AAAAAAAAASk_rc2DEJlEENs_s1600_P4110223.JPG
a3.bp.blogspot.com__yfxzu0GmqAk_VSl7QEhF6PI_AAAAAAAAATI_MwrhcXaHiXU_s1600_P4110231.JPG
a3.bp.blogspot.com__iihZF9MzjE8_VSl7PzvH0wI_AAAAAAAAATE_vbi_wPbyars_s1600_P4110230.JPG
Not shiny like Evocarlos has used to do :unsure: but little cleaner :rolleyes:
chribo
Joined
January 25, 2012
Messages
126
Well done man! Where are you from in france? Maybe you are not too far away from me :)
Marty64
Joined
December 28, 2013
Messages
191
Hi Chribo,
Don't think we are near : i'm living in South of France near Spain. I think you are in germany. :nailbiting:
chribo
Joined
January 25, 2012
Messages
126
Yup thats right. But i have onely an hour to drive until im in france but i guess it will take a lot longer to get to you :)
Marty64
Joined
December 28, 2013
Messages
191
Cylinder block back and rebored to 86.5mm:
a2.bp.blogspot.com__vx8nvbEBI5g_VVSLxoxbB1I_AAAAAAAAAUk_P_C43lisoU0_s1600_P5140221.JPG
a2.bp.blogspot.com___szVkP5mJno_VVSLztjUBrI_AAAAAAAAAU0_0Qk02SY66fs_s1600_P5140223.JPG
Start with gap playing :
a3.bp.blogspot.com__NyEN3pFnE7A_VVSLyEVcWcI_AAAAAAAAAUo_ZjDIclEEzqQ_s1600_P5140224.JPG
a1.bp.blogspot.com__2G0PUoOSzao_VVSL93Mo3nI_AAAAAAAAAU8_OokPNhA_N50_s1600_P5140226.JPG
Ring gap between 0.3" and 0.4" , do you think it's correct to a S/C application ?
Marty64
Joined
December 28, 2013
Messages
191
Mon ami, did you really mean that big a gap? or did you mean mm not inches?o_O
Yes Timbo : your right ! ;)
My feeler gauge is in mm !
So, end gap is between 0.0118" and 0.0157"
bore x application = gap :)
eg 3.38" x 0.0045" = 0.016"
Thank's Evo ;) i understand now how to read this table !
My end gap is little tight, in my case i must have:
86.52mm /25.4 = 3.40"
3.40" x 0.045" = 0.00153" for top ring
I must buy a more precise feeler gauge and found a cutting wheel.
Supercharged application are not like "Street moderate - Turbo" 0.0050" gap ?
Thank's men (y)
Joined
November 11, 2006
Messages
9,930
thats still a .0016" gap thats what im using .038mm - .040mm on the top ring the 2nd ring did not need adjusting on mine but you may have to with the Over size bore
turbo would be more power than supercharged
Marty64
Joined
December 28, 2013
Messages
191
Some new parts imported from Autovaux:
(crank seal rings, crank bearings and guide, conrod bearings, crank pulley bolt, GM sealant)
a2.bp.blogspot.com___xEkviEqgG8_VYg5NNCxrJI_AAAAAAAAAWI_Mg1JisuLCjQ_s1600_P6220218.JPG
And used parts with only 5.000 and 10.000 miles from "the Bay":
(Oil pump, rockers, lifters, LSJ cover cam with coil cover, LS4 T/B)
a1.bp.blogspot.com__vYjJ1l_7KB4_VYg5MAANiEI_AAAAAAAAAWA_6pNdNgiEfIc_s1600_P6220219.JPG
Have to found good torque wrench to screw all of this
Marty64
Joined
December 28, 2013
Messages
191
Good Bye GEXXX :cry: (Sold today)
:stop: Money will be used to purchase my future VX220 next year :Punch:
Top Bottom
