with the OBD-tuner software you can use a TMAP sensor in your setup. Now I was thinking, why not replace the temp.sensor from the intake pipe into the intake manifold? How much boost can the OEM map sensor handle?
Yeah I knew that. Just wondering if you could move the temp sensor from the intake to the manifold and have an alternative "T+MAP" idea.
But just found out that the OEM map will probably be blown out cause of the lack of a screw holding it in.
Now I have an uprated VXT intercooler with a TMAP hole allready in so I think I'm gonna stick the TMAP in there and be done with it:
