Most of the guys who have boosted use Courtenay Sport Ltd (https://www.courtenaysport.co.uk). I believe you send your ECU to them for a 'base' map then once the modifications are complete you take the car to them for a full remap on a rolling road.
Someone else should be able to provide further information and approximate costs.
This was discussed a month or so ago, the stock ECU can be used for superchargers not turbo's with the Courtenay map.
i forget what the outcome was regarding turbo's as the stock turbo vauxhalls use a maf and cam sensor not found on the z22se.
Stand alone?
you need to email peter v.d munckhof ,[email protected] ,also known as dutch software,, but before you email him you need to know what spec of engine you are going to be using , eg turbo ,standard z22se engine , and any mods you have planned for your build so he can build you a base map,,
only seen one done and he used standalone ecu ,, not saying youre wrong ,but ive not seen it ,,, when doing mine the t8 management was to complicated ,, and you needed all the ecu,s from the donor car for it to work,,
he,s on z20net on facebook,, he had a Vectra 2.2 and a z20net for parts ,swapped all bits over like turbo,inlet manifold , all ecu,s etc,etc, its still running,
Not going to be very simple to do on the Astra.
Dave had to swap all the controllers from the z20net to his z22se vectra c.
for you it would be easier and cheaper to go stand alone or get the Astra ECU remapped for turbo as figo said above.
