corsaZ22se
anyone got any data for rebuilding the m32 box please?
torque settings for diff housing bolts and sequence?
end float for shimming the shafts?
rebuilding one for a friend in his 1.3cdti corsa d. usually problem 6th gear bearing gone at below 40k miles
going for the later type end case with larger bearings and better oil ways.
and before you say its not the m32 it is in this one as it's already out in bits.
