M32 info please
slindborg
So why do you need new shafts (youroper) when fitting the M32?
Is the position of the 'diff' different?
is it just a splines inside the diff issue or what?
the splines are different, the diff is approx 10mm over from a F23, so the standard shafts would work, you just need some inner cv's which fit the vx220 driveshafts and the M32 diff
unless you get Gripper to make you a M32 lsd with f23 splines :silent:
slindborg
That was my thought.... I know you can get small block vauxhall gearboxs (F13/15) modded to take 'big block' CV's by simply changing the F13/15 diff splies to F16/20 ones :)
Cant be "that" hard to do it with an open regular diff.....Would take a shed load off the conversion cost :LOL:
