NICKYB
hi all, hoping someone may be able to shed some light onto a easy fix for a gearbox problem?
its onlt a 56 plate zafira 1.9 cdti and its on a M32 box which turns out to be the same as most of the VXR range except for vectra VXR (i think?)
its deff the same as astra VXR, corsa VXR, zafira VXR and the mk5 astra 888.
the weird thing is that it can handle the power of the above cars yet it seems to have broke in a zaffy diesel!
the problem:-
while inspecting it found that the passanger side CV moves around 1/2" up and down so removed that and its actually the diff gear in the box thats moving about. have a word with a VX dealer and they said that it is something that has been known before and as always, VX suggest 'needs new box'!
the main question is, as its only the diff thats the prob, can this be repaired? has anyone fitted a LSD to a VXR and has a diff laying about? has anyone come across this before and found a cure? etc., etc.?
any help would be great!
many thanks nick
the problem:-
many thanks nick
