IDI AMIN
Car failed m.o.t on exhaust emissions so would be grateful for tips on how to sort it list is as follows
Exhaust emissions carbon monoxide content after 2nd fast idle excessive [ 7.3.D.4]
Exhaust emissions hydrocarbon content after 2nd fast idle excessive [ 7.3.D.4]
Exhaust emissions Lambda reading after 2nd fast idle outside specified limits [7.3.D.4]
Fast idle test readings
MAX LIMIT ACTUAL VALUE
CO 0.300 0.459
HC 200 209
LAMBDA 1.030 1.039
SECOND FAST IDLE TEST
CO 0.300 0.455
HC 200 210
LAMBDA 1.030 1.033
I've only listed the readings it failed on hopefully someone can help someone has already suggested injector cleaner so i'm wondering what others suggest. would redex help any . There is a few others on the mot list but i can sort them its just the emissions i need advice on thanks
hope you can understand the list i tried to space it but when posted all readings are together
CO 0.300 0.459
HC 200 209
LAMBDA 1.030 1.039
CO 0.300 0.455
HC 200 210
LAMBDA 1.030 1.033
