Low engine oil affect chain?
Discussion in 'Cam Chains' started by richard165, June 17, 2017.
Tags:
  1. Hey
    I was on return trip from airport on motorway and 'check engine oil level' was shown on info display. Pulled off m way and warning went off.
    Got home and it was about 600ml low.
    Will this have caused any wear or damage? No wierd noises by the way
    Thanks
  2. should be totally fine (y)
    • Like Like x 1
    • Agree Agree x 1
  3. Thanks:)
    I was just checking because when we first got the car she got same check oil level then chain went.
    Thank you for quick reply!
Matched Content
