Which threads are you seeing as slow Carl? I've never noticed it being slow, other than on threads where the images aren't ones we are hosting on here.nice does this mean when i look at forum attachments i wont have to wait a age to look at 10 pics ?
Hmm, just had a look. I can see that it's going to be slow depending on your own connection speed. Each of those images is over 3MB each, and using the Chrome tools, it seems that lightbox loads ALL the images to generate the thumbnails and the initial image, and then it loads the image and thumbnail again as you scroll across. So it's loading a s**t load of data! Let me see if there is anything I can do.but this one i tryed to look at the pics last night and spent the best part of an hour trying to look at each pic (post 2) album
https://z22se.co.uk/threads/engine-will-not-start-after-rebuild.21863/
There isn't a user set up on the dev site, there is only me registered. Should be OK if you register on there.6Mb/s best i can get out in the sticks it somtimes pecks at 10Mb/s
http://www.speedtest.net/result/2461918596.png
same user name and pass as this site ?
for the dev
I've fixed the issue with registration on the dev sitethat one loads up instant now
but i cant register goes to bad gateway
i,ll try again
Ok. Here are the request/response headers from your attachment:
Code:Request URL:[URL]https://z22se.co.uk/attachments/2012-09-19-09-50-24-jpg.8944/[/URL] Request Method:GET Status Code:200 OK Request Headers Accept:text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8 Accept-Charset:ISO-8859-1,utf-8;q=0.7,*;q=0.3 Accept-Encoding:gzip,deflate,sdch Accept-Language:en-US,en;q=0.8 Cache-Control:max-age=0 Connection:keep-alive Cookie:<removed> Host:[URL='http://www.z22se.co.uk']www.z22se.co.uk[/URL] Referer:[URL]https://z22se.co.uk/threads/engine-will-not-start-after-rebuild.21863/[/URL] User-Agent:Mozilla/5.0 (Macintosh; Intel Mac OS X 10_6_8) AppleWebKit/537.17 (KHTML, like Gecko) Chrome/24.0.1312.57 Safari/537.17 Response Headers Cache-control:private, no-cache, no-store, proxy-revalidate, no-transform Connection:Keep-Alive Content-Disposition:inline; filename="2012-09-19 09.50.24.jpg" Content-Encoding:gzip Content-Type:image/jpeg Date:Sun, 03 Feb 2013 23:54:12 GMT Etag:1352049415 Expires:Thu, 19 Nov 1981 08:52:00 GMT Keep-Alive:timeout=5, max=100 Last-Modified:Sun, 03 Feb 2013 23:54:12 GMT Pragma:no-cache Server:Apache Transfer-Encoding:chunked Vary:Accept-Encoding,User-Agent X-Content-Type-Options:nosniff X-Powered-By:pHP/5.4.11
Here are the headers for an attachment on my test forum:
Code:Request URL:http://<mytestsite>/attachments/dunmorogh_ridgecamp-png.28/ Request Method:GET Status Code:304 Not Modified Request Headers Accept:text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8 Accept-Charset:ISO-8859-1,utf-8;q=0.7,*;q=0.3 Accept-Encoding:gzip,deflate,sdch Accept-Language:en-US,en;q=0.8 Authorization:<removed> Cache-Control:max-age=0 Connection:keep-alive Cookie:<removed> Host:<mytestsite> If-Modified-Since:Sun, 03 Feb 2013 01:26:51 GMT If-None-Match:1359247650 User-Agent:Mozilla/5.0 (Macintosh; Intel Mac OS X 10_6_8) AppleWebKit/537.17 (KHTML, like Gecko) Chrome/24.0.1312.57 Safari/537.17 Response Headers Cache-control:private, max-age=0 Connection:Keep-Alive Date:Sun, 03 Feb 2013 23:58:12 GMT Expires:Thu, 19 Nov 1981 08:52:00 GMT Keep-Alive:timeout=5, max=150 Server:Apache
You can see that "If-None-Match" is not being submitted when I request your attachment, but it is being submitted for my attachment. That is the nature of the problem. The question becomes why is it missing from the request? I believe it is related to these response headers from your forum:
Code:Cache-control:private, no-cache, no-store, proxy-revalidate, no-transform Pragma:no-cache
That would instruct my browser to not cache the resource.
I can't find where this response header is coming from. Perhaps something from your Apache config?
# Force no caching for dynamic files
<FilesMatch "\.(php|cgi|pl|htm)$">
ExpiresActive Off
Header set Cache-Control "private, no-cache, no-store, proxy-revalidate, no-transform"
Header set Pragma "no-cache"
</FilesMatch>
Request URL:https://z22se.co.uk/attachments/2012-09-19-09-50-24-jpg.8944/
Request Method:GET
Request Headers
Accept-Language:en,en-GB;q=0.8
Cookie:<removed>
Host:www.z22se.co.uk
If-Modified-Since:Mon, 04 Feb 2013 00:38:41 GMT
If-None-Match:1352049415
User-Agent:Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.17 (KHTML, like Gecko) Chrome/24.0.1312.57 Safari/537.17
Response Headers
Date:Mon, 04 Feb 2013 06:25:33 GMT
Server:Apache
