LHD CENTER CONSOLE with GPS (sat nav)
Marty64
Hi,
I'm looking for part number of a LHD Center Console with GPS and auto climate in Beige (Bronze)
Like the number 8 in the pic but can't find part number.
Only found 2 part numbers:
item 5 GM 9196595 OPEL 7209004 RECOUVREMENT CENTRAL,TABLEAU DE BORD,CAG,BRONZE (UTILISER AVEC ECRAN DE SYSTEME DE NAVIGATION)
item 6: GM93171166 OPEL7208547 RECOUVREMENT CENTRAL,TABLEAU DE BORD,CAG,BRONZE (UTILISER AVEC ECRAN DE SYSTEME DE NAVIGATION)
Someone write in another forum that is
GM 9196595 : Cover, centre, instrument panel, left hand drive, bronze
part number need.
But when i'm looking image, i'm not sure about it and not sure if "BRONZE" is my color.
Here the color i'm looking for:
Marty64, do you know what the trim code is on your car. It is usually found on the sticker on the driver's door pillar and is next to the paint code - usually XX??
Marty64
Hi KEvin,
For me the sticker is on the passenger door's side :D
My code is XXLN, i think the color name of console could be "bronze"
Hi Marty,
For info, Vauxhall/Opel list XXLN as "Light Beige".
Another question - Does your car currently have electronic air conditioning (climate control) or is it just standard ?
Edit: Sorry, from the picture above it has climate control.
Marty64
Electronic air con.
The pic above is from my car. Just need the same console with extra LCD CID location.
Don't take too much time to search part number, i found a GPS console with same color but with manual clim con.
I will cut both consoles to make one :wacky:
Marty64
Received GPS Console with manual climate control and removed my MFD Console with auto climate control:
I cut in two the two consoles:
Swap the upper parts and glued them:
Was a bit of pain to fit CID on this support cause i have a Vectra CID version and was too large.:banghead:
I cut plastic around CID and put some screws.
After that job was done !! :love:
Now, have to found why i don't receive GPS signal :cry:
Marty64
Thank's Dave ;)
Yes i seen the Tofferson's blue one.
Yes mine is an original, before steering wheel was all in black and swap it for an Astra 2.0 Turbo beige version (same color as door panels, center console and leather seats).
#13
Hi Marty64, do you know what is the part number of the number 7 in your picture? I'm looking for this in black color because the watch clamping is broken and I want to replace it. And I can't find how I can buy it!
Thanx in advance :)
Hi,
part number need.
