Just put on my new chains and viola. im soooo happy THANK YOU ALL for your help. Just need to check for leaks for the next few days and water level too. this i by far the most technical thing ive ever done
yeah for sure, but id turned the wheel manually first to check for any feedback. then put a wee bit oil down into the cylinders. then turned her over to build oil pressure and listened for any danger signs. then went for it and with a poof of smoke she rumbled back into life.she ran really rough. but i thought it would be the ECU just recalculating everything. turned her off and on again and all is sweet. just had her up too operating temp for a wee bit, checking for leaks and what not. all is good
