OK, just for peace of mind I wanted to measure how much vacuum is being pulled from my crankcase at various driving conditions with the extra 3.5mm Ø post-throttle PVC line.
First I thought of rigging a spare oil filler cap with a fitting and hose leading to a vacuum gauge ...
... but as Z22SE oil caps are curiously hard to come by here around, I decided to skin the cat another way.
So I rigged a makeshift airtight plug of the adequate size, pulled out the oil dipstick, inserted the plug into the dipstick tube, lead a hose from the plug to a vacuum gauge, and duct taped the gauge to the base of my windshield. As ghetto as they come but it worked fine.
Now the Gunson gauge I used is designed to measure inlet manifold vacuum, and is graduated in inches of mercury (" Hg):
To measure the very slight crankcase vacuum that I was expecting to register beforehand, some manometer graduated in inches of water (" H2O), like a Magnehelic or a makeshift U-tube, would have been more adequate (1" Hg = 13.6" H2O). But Magnehelics ain't cheap, I wasn't in the mood for more bricolage, and all that was needed was to verify that my crankcase vacuum wasn't shooting up to some worringly high level under any driving condition.
Once on the move, the needle in the Gunson vacuum gauge barely wobbled above 0" Hg at idle or under acceleration, and only on a long downhill coastdown overrun with my foot off the throttle pedal did it move a bit closer to 1" Hg.
So no worries, as expected there's only a very slight crankcase vacuum, enough to ventilate and relieve crankcase pressure and make the rings work better, but far too low to generate problems with gaskets/seals or oil pressure.
*** For those interested in the symptoms of excessive crankcase vacuum, at about ~7" Hg of crankcase vacuum you start hearing weird whistling noises coming from the engine
(that's outside unfiltered air forcing its way into the crankcase thru gaskets/seals, nature abhors a vacuum), then at about ~14" Hg of crankcase vacuum your oil pressure starts dropping down dangerously.
