The inner boot is smaller than the outer..
What I do is cut the boot clips off slide the boot down the shaft then clear some of the grease away and you should see the clip it's clipped around the shaft..
I've stripped down a vectra and an astra shaft and made a good one out of the 2 tonight and it's a messy job but pretty easy
