I didn't realise that XF had the ability to resize images as they are uploaded, which meant that all images being added here we the full size (behind the 600x600 pixel thumbnail).
I've now set it to scale down any images larger than 2560x2560 (they will get scaled down to the axis which matches the longest side).
This should help with threads that have a few large images inside them, as the full images will be considerably smaller as they are scaled back down.
The only limiting factor is if the image is larger than 20 megapixel, as this may throw an error, as that is a hard limit set by the software.
As an end user uploading images, you shouldn't notice any difference
