How can I remove intake manifold?
Discussion in 'Car Discussion' started by Grecu Marius, June 10, 2017.
  1. How can i remove the intake manifold from a z22se , i want to fit the 2.4 one:D
  2. it is quite easy, just remove ECU, remove dipstick bolt, remove throttle body, remove the bolts and two nuts holding the inlet to the engine. It is easier if you remove the two studs as well - use a small torq socket
    • Agree Agree x 1
    • Useful Useful x 1
  3. It's depends on car model. For Zafira it's pain, even got to remove air conditioner tubes from compressor in order to remove the manifold.
  4. I do love my zafira but that job made me curse!
