Hello guys, I have a new camera and I don't know what to put in these boxes in the picture. It's a wireless one that works from Wi-Fi, it's got me beat . Any info would be great
there will be default username and password for the device and then a port to test it mine has to be plugged in to the net cable to set up then switched over to wireless at the end
what model is it?
Has it actually been setup to connect to the wireless network? As Carl said, they usually need plugging in using a ethernet cable first to set up and then you can go wireless.
I have it setup on my phone and it's working fine, it's just the main software I can't get to work lol. Any other good cctv software out to try? Cheers guys
