Hand Brake cable change and adjustment (version 1.0) - Hand Brake cable change and adjustment
to change the handbrake cable's the car will need to be jacked up and put on axle stands on flat ground and in a safe manner
once the car is up and you are able to get underneath the exhaust will have to be removed this may not be easy depending on how old the clamps are
once the back box and center section are removed you will need to remove 2 nuts from one side of the heat shield at the fuel tank end
the heat shield can then be bent down out of the way
revealing the handbrake connection...
